1998 Plymouth Voyager Flashing lights
1998 PLYMOUTH VOYAGER
168,000 MILES • 6 CYL • FWD • AUTOMATIC
TPSHEP
My wife had locked her keys in the car, with the key on to listen to the radio. The battery went dead, but was jump started easily. Ever since then, the lights for the rear wiper, intermitten rear wiper, in-air circulation button, and cool button are fashing. I have tried to disconnect the battery to maybe reset it, but nothing is working. Any suggestions? Thanks.
Feb 3, 2009 at 9:33 PM
RPTASIUK
  • 7 POSTS
The flashing lights indicate your Environment Control Computer needs calibrating. Here's how:
With engine running...
Turn blower motor to high
Set mode position to dashboard vents only
Open all the vents
Set the temperature to cold (both slide pots if equipped)
Depress wash and rear wiper simultaneously for 5 seconds (until ALL LED's light)
RESULTS
All LED's will turn on for 5 seconds
Calibration test is running when rear wiper and intermittent are alternately flashing. Cooldown test is running when A/C and RECIRC are alternately flashing.
Acceptable result is REAR WIPER LED is the only LED flashing. Push REAR WIPER to exit.
Sep 27, 2009 at 1:43 PM
