1998 Plymouth Voyager Belt Slips on AC compressor or AC Com
1998 PLYMOUTH VOYAGER
100,000 MILES • 6 CYL • FWD • AUTOMATIC
SENIORCITIZEN
I recently bought this van and the person told me that AC compressor is broken and there was no belt on, however I put the new belt on and AC seems to be cooling fine but after a while I can see that AC pully (when AC clutch is engaged or is turned on)seems to be stopping and moving and the belt is slipping on it. Is it the pully bearing or the compressor itself. Thanks.
May 24, 2009 at 3:34 PM
The compressor it self is locking up. Chances are it will need replaced. Keep in mind, when you use the defroster, the clutch will do the same thing because it works in conjunction with the defroster.
May 25, 2009 at 8:12 PM
