1998 Plymouth Voyager Ac compressor won't turn on - (1998 P
1998 PLYMOUTH VOYAGER
134,000 MILES • 6 CYL • FWD • AUTOMATIC
GG1328
  • 21 POSTS
I purchased the above vehicle 2 weeks ago. According to the Haynes manual, in order to put R-134 in, you have to place a jumper on the low pressure cycling switch, if the ac compressor is not running. It does not show where the switch is and what it looks like. Can any body tell me where it is and what it looks like.
Thanks,
George
May 14, 2008 at 9:03 PM
MIKE H R
  • 3,094 POSTS
you can find it by following the line and you will see it inline with two wires going into a round rubber connector. it is plugged into the line by way of low pressure switch. Use a jumper wire and jump the two wires then the compressor will come on, allowing you to refill the ac
May 15, 2008 at 10:06 AM
GG1328
  • 21 POSTS
Thanks for your help, but the only thing that I see is a 3 wire plastic connector(not 2 wires) left and below the alternator, connected to a little round metal piece. I tried pulling on it, but it won't budge. I'm afraid that I will break the line. Is this the right connector and how do I get it off?
Thanks,
George
[quote:fc5fb47e72="M_J_RITZEL"]you can find it by following the line and you will see it inline with two wires going into a round rubber connector. it is plugged into the line by way of low pressure switch. Use a jumper wire and jump the two wires then the compressor will come on, allowing you to refill the ac[/quote:fc5fb47e72]
May 15, 2008 at 6:50 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:283dac8307="gg1328"]Air Conditioning problem
1998 Plymouth Voyager 6 cyl Front Wheel Drive Automatic 134000 miles
Thanks,
George[/quote:283dac8307]
Hi George,
Ok, are you sure that it is low on freon? If you are and since the system is empty or empty enough that the compressor wont come on you can before starting the vehicle hook up your hose to the low side and then start the vehicle and open the can once system is full enough the compressor will kick in then just fill it till the gauge reads correct pressure.
I have done this many time with no problems.
Mark
May 15, 2008 at 10:11 PM
MIKE H R
  • 3,094 POSTS
The low pressure cut off switch is located on side of expansion tank. it looks like attached
https://www.2carpros.com/forum/automotive_pictures/54223_stemt0470002_1.jpg
May 16, 2008 at 9:51 AM
