4 (REAR WIPER, REAR WIPER DELAY, RECIRCULATE, AND AIR CONDITIONING) OF THE 5 LED'S FLASH FOR ABOUT 15 MINUTES ON THE DASH (BODY CONTROL MODULE) AFTER START UP. ALL FUNCTIONS STILL WORK FINE. AFTER THE TIME HAS PASSED, THE LED'S STOP FLASHING AND WORK NORMALLY, ON WHEN THE REAR WIPER IS ON, OFF WHEN REAR WIPER IS OFF, ETC. IS THIS A CODE? STARTED WHEN SIZZLING NOISE OCCURED WHEN STARTING CAR. TURNED IGNITION OFF, BUT SIZZLING CONTINUED FOR A WHILE. ONLY TWO LIGHTS FLASHED THEN. HAPPENED AGAIN AND NOW 4 LIGHTS FLASH. MIGHT HAVE BEEN A CAR ALARM RELAY STICKING PROBLEM THAT CAUSED THIS. IS THERE A CODE I CAN ACCESS JUST BY TURNING IGNITION KEY ON AND OFF? TRIED HOLDING TRIP AND OD BUTTONS AND CODE WAS "EVERYTHING GOOD". NOW WHAT? THANKS. JOHN
May 5, 2008 at 11:58 AM
