1997 Plymouth Voyager Ticking noise in engine
1997 PLYMOUTH VOYAGER
FISHINGNUT79
Noises problem
1997 Plymouth Voyager 6 cyl Front Wheel Drive Automatic 134k miles
Does the 1997 Voyager with the 3.0 V6 have hydraulic lifters? I need to know if I need to replace a stuck lifter. I have tried Gunk motor flush and Rislone engine treatment and the ticking has not stopped. Thank you for any help.
Oct 21, 2008 at 8:24 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Hello, Yes, it has hydraulic lifters. and they should be fairly easy to replace. However, I would recommend replacing all of them. I found on my personal vehicle trying to save a little ended up costing more. So, after the 3rd time in 4 months needing to replace a single lifter I decided to replace the rest. Here is a pic.....
https://www.2carpros.com/forum/automotive_pictures/188069_lifter_1.jpg
Oct 21, 2008 at 8:31 PM
