1997 Plymouth Voyager Oil Pressure Alarm
1997 PLYMOUTH VOYAGER
191,000 MILES • 6 CYL • FWD • AUTOMATIC
THEGOODPERSON
I recently had the timing chain and oil pan gaskets replaced. Now the oil pressure lights comes on along withh the alarm. This happens only when I ome to a stop. When I out the van in nuetral the alarm goes off. What could it be?
Oct 1, 2010 at 9:51 AM
MERLIN2021
  • 17,250 POSTS
Check the oil pressure with a gauge, unscrew the oil sending unit, screw in the gauge and take readings with engine fully warmed up, this spec is for 3.0 V6.
Oil Pressure Oil pressure should be 6 psi (41 kPa) at idle and 35-75 psi (241-517 kPa) at 3000 RPM with engine at normal operating temperature.
Lower readings usually indicate worn engine parts, or weak oil pump. Ask if the mechanics cleaned the screen in the oil pan. It is the pick up tube screen.
Oct 1, 2010 at 11:14 AM
