1996 Plymouth Voyager Warning chime soounds, no idiot light
1996 PLYMOUTH VOYAGER
140,000 MILES • 6 CYL • FWD • AUTOMATIC
PASTODIAN
All idiot lights function at ignition on (no bad bulbs). Van starts easily, engine sounds fine. No warning lights show.
After 10-15 seconds the warning chime starts sounding and continues dinging (again with no idiot lights showing; door ajar, seat belt, temperature, brake, oil pressure, etc.)
Quick self diagnostic (ignition on-off-on) shows only code for battery disconnect within 100 key ons (12) and end of codes (55).
Any idea what's going on? Is there any way to diagnose problem? Is it safe to drive to mechanic?
Nov 8, 2009 at 8:26 PM
BMRFIXIT
  • 19,053 POSTS
Need the help of a scanner
BCM should show why and or what
Nov 8, 2009 at 8:39 PM
PASTODIAN
Thanks. Is it safe to drive it to a shop with a scanner?
Nov 9, 2009 at 8:43 PM
BMRFIXIT
  • 19,053 POSTS
check your fluids and it should be safe to drive
Nov 10, 2009 at 4:22 PM
