I have a 96 Voyager check engine light came on and the mechanic said it was an o2 sensor, replced 3 days later the car turned off and the light came back on. What can be the problem I have changed the o2 sensor, cam shaft sensor, crankshaft sensor as well because all thiese were codes thatcame up on the diagnostic. The car also takes a while for its temp. to reach it level so I will replace the thermostat and do a radiator flush..what can be the couse of my check engine light..
Mar 31, 2008 at 6:04 PM
