Do this transmission have a modular valve or is there something to change to help the transmission to shift gears.
I have changed the fluid and filter. Before changing the transmission ....is there anything I can do to make the transmission start shifting. It stays in one gear. It will go up to 60 plus miles per hour. It just want shift into a another gear. This makes the RPM run at around 4000 plus rpms.
Aug 13, 2009 at 7:10 AM
