1996 Plymouth Voyager No Brake lites when i apply the brake
1996 PLYMOUTH VOYAGER
121,000 MILES • 6 CYL • FWD • AUTOMATIC
HOBBYMECHANIC7
I've checked the bulb in the rear, also the third brake lite has 3 12 volt 921 bulbs I replaced. I checked the fuse box under the dash, and I checked the fuses and relays in the engine compartment. I also checked the brake switch mechanical operation, I didnt check for current at the brake lite switch on the pedal i didnt want to short anything out and deploy the air bags. I'm stumped.
Dec 27, 2009 at 9:31 PM
BLUELIGHTNIN6
  • 16,542 POSTS
you will need to test the brake lamp switch..this is the most likely cause for this problem.
Dec 27, 2009 at 9:33 PM
HOBBYMECHANIC7
You were absolutely correct, I check the brake switch, replaced the switch for $11,00, thanks you very much.
Dec 30, 2009 at 9:12 AM
