1996 Plymouth Voyager LEAKING TRANS FLUID
1996 PLYMOUTH VOYAGER
151,000 MILES • 6 CYL • FWD • AUTOMATIC
BASSDAWG
  • 5 POSTS
I HAVE REPLACED THE DRIVER SIDE OUTPUT SHAFT BEARING AND REPLACED SEAL. IT IS STILL LEAKING ON THE INSIDE OF SEAL. MOTOR MOUNTS ARE GOOD AND AXEL IS GOOD. I CAN'T FIGURE OUT WHY?
Sep 29, 2010 at 4:50 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I can only think that either the seal lip was not lubed before installing the shaft and it has been damaged, or the seal was damaged during installation, or an incorrect seal, did you try the seal on the shaft first?
mark (mhpautos)
Sep 30, 2010 at 3:01 AM
BASSDAWG
  • 5 POSTS
yes we did . im going to the dealership to get a new seal . hope it is like the orginal one. the ones we have got so far are a little diffrent. so maybe that is our problem. i just feel like there is something else causing it to leak. thank you and i will let you know how this seal does thank you for your advice.
Sep 30, 2010 at 3:59 PM
2 LINSEY
  • 287 POSTS
Thank you for using 2carpros.com. We appreciate your donation and look forward to helping you in the future. Good Luck!
Oct 6, 2010 at 2:12 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Did the new seal fix the problem?
Mark (mhpautos)
Oct 6, 2010 at 4:05 PM
BASSDAWG
  • 5 POSTS
NO IT DIDNT . SO I PULLED THE OTHESIDE OFF EVEN THOUGH IT WASNT LEAKING AND THE BEARING WAS IN A MILLION PEACES. I REPLACED THE BEARING AND SEALS ON BOTH SIDES LAST THURSDAY IT HASNT LEAKED A BIT.
Oct 12, 2010 at 4:09 PM
MHPAUTOS
  • 31,937 POSTS
Well the good thing is that it is fixed, what i can't understand is why there was not some serious bad noise involved with a failed bearing.....
Mark (mhpautos)
Oct 12, 2010 at 4:21 PM
