1996 Plymouth Voyager Have two codes PO123, PO121
1996 PLYMOUTH VOYAGER
160,000 MILES • 6 CYL • FWD • AUTOMATIC
BUTCH5000
Throttle/Pedal position sensor/Switch A circuit Range/Performane
Throttle/Pedal position sensor/Switch A circuit high
Where do I find the sensor and how do I trouble shoot it?
Oct 9, 2009 at 10:39 AM
JALOPYPAPA
  • 467 POSTS
It's on the throttle body near the throttle shaft, with a three-wire connector. With the key on, and using a multimeter backprobing the connector (I use straight pins and an alligator clip attachment to the multimeter leads), one outer wire should show 5 volts, the other continuity to ground. THe middle one should vary smoothly from about 0.2 to about 5 as you open the throttle.
check here: https://www.2carpros.com/trouble_codes/obd2
Oct 9, 2009 at 11:41 AM
