1996 Plymouth Voyager Fault codes
1996 PLYMOUTH VOYAGER
200,000 MILES • 6 CYL • FWD • AUTOMATIC
6TURTTLES
What does the follow code mean, P1255- Pedal Correlation PDS2 and LPDS Low.
What is PDS2 and LPDS?
Aug 18, 2008 at 10:16 AM
MERLIN2021
  • 17,250 POSTS
Are you sure about this code? I have not found this code for Chrysler/Plymouth...
You can try a self-diagnostic test. To activate self diagnostic program:
With the ignition switch in the OFF position, depress the TRIP and RESET buttons.
While holding the TRIP and RESET button turn the ignition switch to the ON position.
Continue to hold the TRIP and RESET buttons until the word CODE appears in the odometer windows (about five seconds ) then release the buttons. If a problem exists, the system will display Diagnostic Trouble Codes (DTC's). If no problem exists, the code 999 (End Test) will momentarily appear.
Aug 19, 2008 at 2:54 PM
