1996 Plymouth Voyager asd relay
1996 PLYMOUTH VOYAGER
RROBINSON1
Electrical problem
1996 Plymouth Voyager 6 cyl Front Wheel Drive Automatic 185.69 miles
1996 ply voyager 3.0 ltr put a new fuel pump in after about a week the van would just off and will not start for about there 3 hours i check the fuel persure all was in spec i was told to look at the asd relay and to check to crank sensor or cam sensor but i can not find a cam sensor i have new crank sensor but don't want to put it in if it wont fix it even put a new ecm from the dealer still did'nt fix it could someone help
thanks
ron
Mar 7, 2009 at 3:19 AM
BMRFIXIT
  • 19,053 POSTS
Crank sensor is a lot cheaper and easier to do than the PCM computer
did u check if u have spark
cam sensor is located under distributor cap
do check for codes
is engine does not start at all check timing belt
check coil
Mar 7, 2009 at 5:45 AM
