1996 Plymouth Voyager alternator not charging
1996 PLYMOUTH VOYAGER
WARNER76
Electrical problem
1996 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
my batter light comes on and the van shuts down the wipers sometimes don't shut off the lights on the dashboard flicker the dome lights don't work what could be the problem and how do I fix it.
Jan 20, 2009 at 10:32 AM
JDL
  • 16,098 POSTS
I'd make sure the battery has a full charge, the battery cables/ wires all clean and tight on both ends.
I realize your talking about the charging system, but, check for trouble codes. You cycle the key, on--off, on--off, on, you just turn the key till the dash lites come on, no further. Then the check engine lite goes to flashing, you count the flashes to get the codes. I believe this vehicle does have two digit codes for the charging system. Or if the codes point in a different direction, you can go that way.
If you have a digital volt meter, we can check your charging system?
Do you have a theft system?
Jan 20, 2009 at 3:15 PM
WARNER76
thanks I will try that and let you know
Jan 21, 2009 at 9:06 AM
