1995 Plymouth Voyager vibration
1995 PLYMOUTH VOYAGER
178,000 MILES • 6 CYL • 2WD • AUTOMATIC
PLYMOUTH 1995
My van vibrates hard on take off . Feels like it is in the right front wheel area but apparently the wheel is fine.. I just changed the distributor cap... Could it be a bad spark plug or some screw up I did with the distributor cap.. Once I get up to 40 KM / hour the vibration stops.. ? any ideas.. thanks
Apr 11, 2009 at 6:27 PM
CARADIODOC
  • 34,306 POSTS
If you've ruled out a bent wheel or broken belt in a tire, suspect a worn inner cv joint housing, especially if the shaking is in the steering wheel and goes away when you let off the gas. Holler back if you want to inspect it yourself. I've replaced about two dozen for this problem, and it's almost always the right one.
caradiodoc
Apr 12, 2009 at 4:39 AM
