1995 plymouth grand voyager se
1995 PLYMOUTH VOYAGER
LGLOSTER
1995 grand voyager. mileage:160,000 engine size:3.3
I'm really getting frustrated with my van and its fuel problem. I replaced the fuel pump and filters, fuel pressure regulator, both gas lines because the burst on me, spark plugs and wires, the ignition coil pack, fuses, relays, everything basic. I dont know where the map sensor is located to unplug is to test it. Its not getting any gas to the fuel injection thing that squrks gas under the hood is the system is flowing right.No gas at all. when I turn my key over I hear the fuel pump kick on so I'm totally stumped. PLEASE HELP
May 10, 2007 at 6:31 PM
2CARPRO JACK
  • 11,533 POSTS
Need to check for injector pulse. Locate a "noid" light and plug it in to the injector plug and see if it flashes when the engine is cranked. Do you have spark?
May 11, 2007 at 7:42 AM
LGLOSTER
Yes I have a spark, and after all this time I found out what was wrong! On the passager side of the van under the sliding door, that fuel filter had a rubber hose that was lose and had been sucking air into the fuel line. We kept trying to start it up and releasing the air out on the fuel injection bar and gas finally got up there! Unfortunatey as soon as I got it going I put 25 dollars worth of gas in it and that very hose sprung not a leak, but a hole and I lost every drop because I was in motion when it happened! I replaced the hose I she runs like a dream now no problem. 600 hundred bucks for a 15 cent hose!!!!! I have a new problem now, I can't get the key in reminder to stop sounding when I put it in accesory.I don't know if the van has had a kill switch before I got it. Any suggestions?
May 31, 2007 at 9:29 AM
