Hi:
The procedure may differ based on what radio you have. Regardless, try this.
1) turn the radio on
2) Press the set button
3) Press the select button to change from minutes to hour
4) turn the tuner knob to select minutes and hours
5) When you have the correct time, turn the power off and the job should be done.
Let me know if there is something you don't understand, or if your radio doesn't have the items listed.
Nov 4, 2008 at 10:45 AM
