1994 Plymouth Voyager need advice
1994 PLYMOUTH VOYAGER
142,000 MILES • 6 CYL • FWD • AUTOMATIC
MSTUMP
The pedal went to the floor and I have to pump the brake to stop the van. The fluid level was empty and I refilled it and bled the lines alot. I couldnt find a leak anywhere. and I cant get the pedal firm again. I changed the master cylinder and bled the lines again. still cant get the pedal firm like it used to be. I dont see any air coming from the lines.
Feb 12, 2008 at 10:12 AM
MERLIN2021
  • 17,250 POSTS
You can bleed it... Bench bleed the master by getting brass plugs and screw them into the two ports, then pump the master until you cant move the piston any more. Attach the lines, Have an aide press and hold the pedal crack the lines and retighten, repeat this till all air is removed at the lines, Don't let the master run dry, bleed rear cylinders by opening the bleeders and wait until the fluid dripps out. Close bleeders. Make sure the rears are properly adjusted, then test the pedal hieght
Feb 12, 2008 at 10:47 AM
