Kickdown cable at throttle is loose. CV joint left side is bad and will be replaced. Vacuum canister that connects to kickdown cable has a vacuum line connected to it. That vacuum suction seems weak to me.
Vehicle won't shift into 3rd or 4th gear. Tested shifting on steering column. Park, Reverse, Neutral works fine. However, putting it in 1st, 2nd, or drive has no affect. It just shifts hard into first gear and then second.
When I changed transaxle fluid and filter I greased CV Joint and moved tire around a bit. Vehicle shifted and ran beautifully for about three weeks. Then went back to its previous condition.
Thank you in advance for your assistance.
Sep 14, 2010 at 1:23 PM
