1994 Plymouth Voyager Exhaust repair
1994 PLYMOUTH VOYAGER
PA_HIKER
Engine Mechanical problem
1994 Plymouth Voyager 6 cyl Two Wheel Drive Automatic
I have to replace the tailpipe on my son's vehicle, but I ran into a problem. The company that replaced the exhaust system welded the tailpipe into the muffler outflow. This brings up two issues:
- the replacement tailpipe seems to be of a size that would fit inside the muffler, I had thought that up-flow pipes always fit inside the down-flow pipe, am I wrong?
- regardless of which is correct, I need to use a pipe expander to widen one of the pipes, how much can you safely expand a pipe?
Aug 3, 2008 at 8:45 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:cfaf6ce051="pa_hiker"]Engine Mechanical problem
- regardless of which is correct, I need to use a pipe expander to widen one of the pipes, how much can you safely expand a pipe?[/quote:cfaf6ce051]
You can safely expand the pipe up to a 1/4"
Aug 3, 2008 at 9:05 PM
PA_HIKER
Thanks. What about the flow direction? Is it safe to maintain the muffler-over-tailpipe fitting?
Aug 3, 2008 at 9:10 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:4758af4153="pa_hiker"]Thanks. What about the flow direction? Is it safe to maintain the muffler-over-tailpipe fitting?[/quote:4758af4153]
Since the system was welded it didn't matter which way the pipe went on.
Now that you are going to use a clamp you should expand the tail pipe to go over the muffler outlet.
Aug 3, 2008 at 9:20 PM
PA_HIKER
Thanks, that's what I had thought.
Aug 3, 2008 at 9:28 PM
