1994 Plymouth Voyager Excessive shaking while accelerating
1994 PLYMOUTH VOYAGER
145,000 MILES • 6 CYL • FWD • AUTOMATIC
CBRLM
While accelerating my van starts to shake. I have replaced the tires, front wheel hubs and had a wheel alignment where they replaced a inner tie rod on the left wheel. What else should I be looking at to remove the shaking. This all started when I had the tires replaced. The dealer checked the tires 3 times for balancing.
Jan 7, 2008 at 12:12 PM
2CARPRO JACK
  • 11,533 POSTS
I take it that the front end is what is shaking? Rotate tires to rear and see if it changes anything, If not then th eproblem is in th esuspension.Other wise might have a bad tire
Feb 1, 2008 at 12:35 PM
