1994 Plymouth Voyager door chime
1994 PLYMOUTH VOYAGER
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
WHOXTER
door chime won' t such off and door won't latch properly
May 6, 2008 at 6:04 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:2fe3402d24="whoxter"]Electrical problem
1994 Plymouth Voyager 6 cyl Two Wheel Drive Automatic 140000 miles
door chime won' t such off and door won't latch properly[/quote:2fe3402d24]
what door?
If driver or passenger... Does the door Drop down when openned? If yes you need new door hing pins. that should fix problem.
If it is sliding door it may need new rollers. they may have worn down to the point of being misaligned causing same problem.
Please post responses and comments here
May 15, 2008 at 11:55 AM
