1994 Plymouth Voyager
1994 PLYMOUTH VOYAGER
RANDALL77
I have a 1994 Plymouth Voyager with 195,000 miles. It has acquired a problem that I can not figure out. It will be running fine and then it will start kicking and bucking and runs really lean. It will not rev up when you hold the throttle to the floor. Then it dies. I have replaced the fuel pump, fuel filter, and the plugs and wires. The strangest part was it ran fine for 2 days after I replaced all of these things then it started doing it again.
Mar 29, 2006 at 12:02 PM
RAYHUT
  • 134 POSTS
it's a good posibility that one of your CO sensors has gone out.it will make it stop running and kicking and bucking.then again it could be a computer chip is gone to.
Mar 30, 2006 at 5:42 AM
CARMARG
hi
my van was doing the same thing and the mechanic found that the throttle body injection needed to be cleaned and air intake cleared (not expensive job) of course discovered after i had a complete wire check.
have you had trouble with the water pump if so could you let me know. i'm trying to get it changed but am getting all kinds of different estimates for the job.
thx
Apr 1, 2006 at 11:15 AM
CARADIODOC
  • 34,306 POSTS
The problem is no one has listed an engine size, transmission type, or mileage. The water pump jobs are hugely different.
Mar 2, 2017 at 8:14 PM
