1993 Plymouth Voyager whats up
1993 PLYMOUTH VOYAGER
116,357 MILES • 6 CYL • FWD • AUTOMATIC
WELDONS5
well the serpentine belt jumps off when you hit gas i believe the motor mount is bad .. could it be the mount on motor,transmission,or could my belt tensioner be going bad?
Feb 13, 2010 at 9:25 AM
JDL
  • 16,098 POSTS
Welcome to the forum, I'd watch the belt between pulleys, engine running. If a lot of flop in the belt, I suspect tension. With engine turned off, you can shake accessory pulleys, see if anything is loose, everything lines up. Correct belt?
Feb 13, 2010 at 9:42 AM
