shake in front end
1993 PLYMOUTH VOYAGER
11,000 MILES • 6 CYL • FWD • AUTOMATIC
JAMES BYRD
I have a wobble in the front end when the wheel is cut to the right in a curve. Feels like the wheel trying to wobble off had everything checked but axelx and ty-rod are tight. When you come out of the curve and straighten wheel up it stops and only when cut to the right it does it. New brake and calipers the back of the rotor is not in the best shape but dosnt do it when the breaks are applied only when wheel is cut.
May 5, 2010 at 10:35 AM
JALOPYPAPA
  • 467 POSTS
I had an elusive shimmy at slow speeds on accelleration and on turns at higher speeds. Finally tried new motor mounts and that took care of it. Check by watching whether engine shifts more than a little in its cradle when helper shifts to reverse or drive with foot on the brake.
May 5, 2010 at 2:32 PM
