1993 Plymouth Voyager Idle
1993 PLYMOUTH VOYAGER
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
HFLASHMAN
My Voyager has developed an intermittent problem with its idle. In the cold weather it doesn't hold an idle. As long as you keep your foot on the gas the van will run, if you take your foot of the gas the van dies. It can run fine then after its stoped for a few minutes it won't start unless you hold the gas pedal down. But it only does this intermittent.
Feb 22, 2010 at 10:23 AM
LEGITIMATE007
  • 5,121 POSTS
sounds like the throttle position sensor is faulty and in need of replacement.
Feb 28, 2010 at 2:39 PM
LEGITIMATE007
  • 5,121 POSTS
you may also want to check the idle air control valve, could be bad too or just dirty, you should clean it and the throttlebody along with the throttle plate, im sure you'll see a difference in its response
Feb 28, 2010 at 2:40 PM
