1993 Plymouth Voyager Distributorless ignition system
1993 PLYMOUTH VOYAGER
110,000 MILES • 6 CYL • FWD • AUTOMATIC
ALASANDRA
I need a wiring schematic for the DIS (Distributorless Ignition System) in my 1993 Plymouth Grand Voyager (3.3 liter engine). I have the repair manual and have also printed out every wiring schematic available from the web and my mechanic says it doesn't have this particular wiring schematic.
The mechanic put in a used transmission and had to redo the wiring because the transmissions didn't match exactly. Right before the transmission installation was complete the motor would start and now the starter tries but the engine doesn't turn over. The dealer hasn't been able to provide us with anything useful either. I'm really getting desparate here. Please help!
Alasandra
Apr 10, 2008 at 6:41 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:26de8be650="Alasandra"]Electrical problem
1993 Plymouth Voyager 6 cyl Front Wheel Drive Automatic 110000 miles
Alasandra[/quote:26de8be650]
I take it that what you mean by "Right before the transmission installation was complete the motor would start" is that the used tranny was in place and started fine. Have your mechanic check the starter for ground. Also check the Battery for cranking amps. a bad ground could have run battery down.
May 12, 2008 at 8:48 PM
