1993 Plymouth Voyager car runs bad and the coil blowes
1993 PLYMOUTH VOYAGER
16,000 MILES • 6 CYL • FWD • AUTOMATIC
ROY MICHEL
  • 6 POSTS
I had a used motor installed and now it runs lousy and the coil will get hot on the cyl 5 and 2 end and crack and then blow a hole in the plastic. Then the white fusable link will get hot and start smoking.
what could the mechanic have done? Can you install the flexplate wrong so the timing is off
Aug 30, 2010 at 2:54 PM
DOCFIXIT
  • 18,828 POSTS
Hi
May have not hooked up engine grounds. Did it run like that when you picked it up? Is shop rechecking there work?
Let me know
Thanks for donate
Aug 30, 2010 at 3:15 PM
ROY MICHEL
  • 6 POSTS
I am a retired tech, with medical issues. The guy is a neighbor and did it real cheap. he doesn't want to know. I checked all the grounds and wire connectors and vacuum lines. would the eng run if the flex plate was put on wrong
Aug 30, 2010 at 5:20 PM
ROY MICHEL
  • 6 POSTS
I'm still waiting for some ideas.
Aug 30, 2010 at 9:13 PM
DOCFIXIT
  • 18,828 POSTS
Flex plate has nothing to do with timing only coupled crank to trans and provides gear for starting. Was used motor compression checked? What is voltage at coil? check engine light on? Was engine compatable to year,trans and computer?
Aug 31, 2010 at 10:30 AM
ROY MICHEL
  • 6 POSTS
This has a crank sensor bolted to the tranny bellhousing and reads 3 groups of marks that are each 20degrees apart.
Aug 31, 2010 at 11:36 AM
DOCFIXIT
  • 18,828 POSTS
Yes I know that is check engine light on? Please answer last post questions
Aug 31, 2010 at 2:11 PM
ROY MICHEL
  • 6 POSTS
The ck engine light is not on.
Aug 31, 2010 at 3:27 PM
ROY MICHEL
  • 6 POSTS
I have not received a good answer, so please credit my card.
Sep 2, 2010 at 9:43 AM
DOCFIXIT
  • 18,828 POSTS
Please answer questions from Aug. 31 11:30 I can't help without information
Sep 2, 2010 at 10:14 AM
