i replaced the front struts with monroe quick strut assembly, also had the rear leaf spring bushings replaced and at the same time had the rear springs rearched to level the vehicle, as the new front springs raised the front too much, now the ride is very hard and rough, so much so that i have to lower the tire pressure to 28 psi to get a half decent ride, the normal tire pressure listed for this vehicle is 35 psi, what has caused the ride to deterioriate so much and what can be done to fix it.
Mar 1, 2010 at 5:51 PM
