1992 Plymouth Voyager location of crankshaft position senso
1992 PLYMOUTH VOYAGER
175,000 MILES • 6 CYL • AWD • AUTOMATIC
FIFTY6WILD
I have a chiltons manual and the diagram does me no good. I can't find it. Where on the transaxle housing is the sensor. Do I need to take the drivers side front wheel off to see/get at it?
May 13, 2010 at 8:03 AM
2CARPRO JACK
  • 11,533 POSTS
Its a bear to find.It is located on top of the bellhousing, under the exhaust croos over, towards the firewall.
https://www.2carpros.com/forum/automotive_pictures/1639_Graphic_7.jpg
May 13, 2010 at 8:18 AM
JALOPYPAPA
  • 467 POSTS
You pretty much have to get under the car, behind the crossmember, and look forward at the back of the bellhousing to see it.
May 18, 2010 at 5:32 AM
FIFTY6WILD
That's exactly what I did, and even then it was a pain to get at. It was harder to find because the wires were sheared off right at the sensor. I found the harness it plugs into before I found the sensor. It was a big job for one little bolt, but it's done and running fine again. Thanks for your help
May 18, 2010 at 8:04 AM
2CARPRO JACK
  • 11,533 POSTS
Glad to hear you are back up and running.. thanks for using 2Carpros.com
May 18, 2010 at 8:09 AM
