1992 Plymouth Voyager Front heating rims ...
1992 PLYMOUTH VOYAGER
160,000 MILES • 6 CYL • FWD • AUTOMATIC
TONYSTARK
Hi Guys, Here's my front brakes my issue. I have changed the brake caliper on one side, and brake pads on both sides, even before that i had some kind of a heat problem. I do still have brake liquid in both front and back pan, no liquid leaks on the parking spot and the liquid stays the same after checking for a few times.
Brakes been represured properly, still, the left side rim is turning so hot, my hand can't stand the heat.
Pouring a little aamount of water onto the rim produces steam after a short ride (less than 10 miles downtown area). Right side's heating as weel, but not as bad as the left side. So, i tried many things so far, but i can't figure what's going wrong or a way to fix my problems. So if you guys could give some help it would be appreciated.
Thank's for your time help and concern.
May 18, 2010 at 12:48 AM
BMRFIXIT
  • 19,053 POSTS
Suspect and check or replace caliper hoses
May 20, 2010 at 5:48 AM
