1992 Plymouth Voyager fan won't work
1992 PLYMOUTH VOYAGER
162,000 MILES • 6 CYL • AWD • AUTOMATIC
BRISH
my car overheat i replace temperature sensor, thermostat, relay and fan continue overheating
my gauge (stock)on instrumental cluster never show when that happen
that gauge show when is cool or on the center some one can help me out
ps: fan work i just replace the gauge go to center and is overheating
Oct 8, 2009 at 1:47 AM
JDL
  • 16,098 POSTS
Welcome, any codes? You can take the fan connector loose, use jumper wires for voltage and ground from the battery, use an inline fuse. If the radiator won't run, suspect faulty fan. If it does run, check the wiring circuits at the fan relay.
Oct 8, 2009 at 12:32 PM
