1992 Plymouth Voyager cooling fan doesn't work
1992 PLYMOUTH VOYAGER
205,000 MILES • 6 CYL • 4WD • AUTOMATIC
LOUIEB
I have a 1992 plymouth Grand voyager that overheated recently and blew th radiator. I replaced the radiator, filled it up with fluid and got it going again. However the fan will not run. I hooked it up directly to the battery and it seems to work fine. Someone said it may be a relay or module of some kind. Where would this part be found on the car? Do you have any other ideas to try? Thanks.
Jun 6, 2010 at 11:38 AM
Could be the fan relay, coolant temperature sensor and computer
Jun 6, 2010 at 3:25 PM
