1990 Plymouth Voyager Battery going dead
1990 PLYMOUTH VOYAGER
TORRIEGIRL
  • 6 POSTS
1990 Plymouth Voyager 6 cyl Front Wheel Drive Automatic 185.00 miles
Hi in the last three months i had my starter replaced and my battery,then alternator. This past weekend my vehicle sat for four days because i decided to take the bus to work. well this morning i went out to start it and there was loud clicking noise. The van would not turn over at all. My lights worked and the radio also worked. So i brought out a battery charger and kept in on charge for an hour. when i went to start the van it turned over and started,i removed the charger and decided to take the van for a spin. About an hour later i got back home shut the van off and it started right away. Then i waited about three hours and went to see if the van would start,no go just the clicking noise once again. Im wondering if my battery has lost the ability to hold a charge because the dashboard gauge shows the needle still in the plus side. How can i tell if the new battery i bought is faulty . For some reason the van did this during the four days i took the bus to work.
Jun 26, 2008 at 7:36 PM
4 days then its dead-could be an electrical short that's draining the battery or the alternator might not be puting out or the battery is not taking it- Start with this get battery and alty load tested and comeback with the results- Tracking an electrical short
https://www.2carpros.com/forum/automotive_pictures/12900_parastic_draw_1_13.jpg
Jun 26, 2008 at 7:53 PM
