1990 Plymouth Voyager 1990 plymouth grand voyager se 3.3l
1990 PLYMOUTH VOYAGER
133,233 MILES • 6 CYL • FWD • AUTOMATIC
DAVID.KEMP81
I have a big problem. I have replaced the struts, ball joints, cv axles, motor mounts, hubs with bearings, and new tires but the rims are bent just a little. My problem is at around 30 to 45 I get a wobble in the front end and some times on acceleration. I am so tried of trying to fix this van please help. What are all the possibilitiesof whts wrong.
Oct 31, 2010 at 12:57 PM
KHLOW2008
  • 41,814 POSTS
Hi david.kemp81,
Thank you for the donation.
Symptoms inidicates some imbalance and most commoon cause would be the CV shaft inner joints.
You mentioned replacing the cv axles, were the complete shaft replaced?
Did you check the CV shaft inner joints for excessive side movements?
Oct 31, 2010 at 1:22 PM
