1989 Plymouth Voyager will not shift
1989 PLYMOUTH VOYAGER
142,000 MILES • 6 CYL • FWD • AUTOMATIC
BRUCE BLANCHARD
The transmission is "stuck" in 1st gear. I have changed fluid and filter, linkage is ok. what do I do next?
Jun 15, 2009 at 1:35 PM
You need to get the transmission pressure tested to find out more
Jun 15, 2009 at 3:24 PM
MIKEYDAP
  • 6 POSTS
Sounds as if you may be in "limp home mode" which is actually 2nd gear. This occurs when one or both transmission speed sensors go bad. $17 each and get a deep dish socket to replace them.
Of course, get the tranny pressure tested as rasmataz noted.
Jun 27, 2009 at 9:48 PM
