1989 Plymouth Voyager help
1989 PLYMOUTH VOYAGER
170,000 MILES • 6 CYL • FWD • AUTOMATIC
MACHINEGUN
  • 10 POSTS
the van runs fine for awhile, then it seems to lose power, if you give it gas it does nothing, if you stop and shut the van off, then start it again it runs good for awhile ,then it does the same thing, i thought it had water in the tank, i put water remover and changed the fuel filter, it seems to have helped alittle, but the problem is still there, is it possible that the in tank screen is picking up debri?
Jan 23, 2009 at 12:47 PM
Check the fuel pressure, throttle position sensor and manifold absolute pressure sensors make sure its within specifications to include checking the EGR valve
Jan 23, 2009 at 1:14 PM
MACHINEGUN
  • 10 POSTS
could it be debri in the tank that im picking up? will i be wasting my time if i drop the tank and drain it, should i run a code scan first?
Jan 23, 2009 at 6:02 PM
You won't get a code for a fuel pressure problem-check the fuel pressure with a fuel pressure gauge then comeback with it for interpretation
Jan 23, 2009 at 6:10 PM
MACHINEGUN
  • 10 POSTS
does it make sense that it runs fine for awhile, then no power, but when i shut it off for awhile, it run fine for awhile again?
Jan 23, 2009 at 6:19 PM
When this happens check the fuel pressure immediately-give me something to work with this is becoming a nightmare-start checkin all the things I have mentioned then get back with some results
Jan 23, 2009 at 6:52 PM
MACHINEGUN
  • 10 POSTS
i had the fuel system checked, the results are the pressure is good, but it has low volumn.
Feb 6, 2009 at 7:23 AM
A fuel pump that delivers normal pressure may still cause driveability problems if it can't deliver enough fuel volume to meet the engine's needs. A fuel volume test may therefore be the best way to evaluate the pump's condition.
A fuel volume test measures the volume of fuel delivered over a specified interval. This test can be done by connecting a fuel flow gauge into the fuel supply line, or by disconnecting the fuel return line from the fuel pressure regulator and connecting a hose from the regulator to a large container. Caution: Make sure there are no open sparks or flames nearby while doing this test!
With the engine off, energize the pump and measure the volume of fuel delivered during the specified interval of time. As a rule, a good pump should deliver about one quart of fuel in 30 seconds.
Causes of low fuel volume delivered include a worn fuel pump, a plugged fuel filter or inlet sock in the tank, obstructed fuel line or nearly empty tank. Don't forget that low voltage at the pump can also prevent it from running fast enough to generate adequate fuel flow. The pump's supply voltage should be within half a volt of normal system voltage. If it is low, check the wiring connectors, relay and ground.
Feb 6, 2009 at 11:39 AM
