I have a engine that is contuniously overheating. I Installed a 160 degree thermostat,new radiator,hoses everything. I did notice when it overeheated last and anti freeze spewed on the maniforld, the motor was running and it has some liquid in the manifold it was bubbling a lot. I assume the new gasket I installed on the manifold was not installed right and is leaking. But will this leak cause the engine to overheat and stay on the hot side. It took about 20 minutes last time for it to overheat.
May 29, 2009 at 5:17 PM
