1991 Plymouth Sundance how to set the distributor timing
1991 PLYMOUTH SUNDANCE
180,000 MILES • 4 CYL • FWD • AUTOMATIC
JSNDMR31
MEMBER
1 POST
FOLLOW
how do you set the distributor timing and to what degree?
Jan 9, 2010 at 9:12 PM
CERTIFIED EXPERT
Put engine no.1 piston on its compression stroke/TDC and line the markings at the vibration damper to 0/TDC and verify that the rotor is pointing to the no.1 cap tower-Now hook-up the timing light and adjust the ignition timing to 12 deg BTDC
