1988 Plymouth Reliant will not start
1988 PLYMOUTH RELIANT
140,000 MILES • 4 CYL • 2WD • AUTOMATIC
DOG11111
wondering why this car will not start it turns over but not starting checked the fuel system seems ok. How do i check to see if the engine is firing!!!
Mar 12, 2009 at 9:42 AM
If it fires and runs a few seconds with starting fluid (follow directions on can) then it is getting spark and there is a problem with the fuel system. If it doesn't even try to start, pull a plug, connect the plug wire to it, ground the plug against the engine block or other ground, and crank the engine to see if you are getting spark at the end of the plug.
Let me know what you find.
joe
Mar 22, 2009 at 12:19 AM
