1988 Plymouth Reliant timing belt
1988 PLYMOUTH RELIANT
FRANK718
  • 14 POSTS
1988 Plymouth Reliant 4 cyl Automatic 40000 miles
why is my timing belt jammed at one point on my 1988 plymouth 2.5 motor? it will turn to one point then jam. the engine will crank over,but the distributor rotor does not. are these related? does the timing belt have anything to do with spark to the distributor? these are related?
Jul 30, 2010 at 11:01 AM
DOCFIXIT
  • 18,828 POSTS
T Belt has shreaded teeth and yes T bellt has everything to do with spark and engine running. Need to replace belt
Jul 30, 2010 at 11:08 AM
FRANK718
  • 14 POSTS
the timing belt is jammed. what can it be jammed on.. in? stops distributor rotor from turning? these answers are so much appreciated. thank you.
Jul 30, 2010 at 11:35 AM
