1987Plymouth Reliant
1987 PLYMOUTH RELIANT
HENRY396
I Just Changed The Fuel Tank And Fuel Pump Holder .Now It Doesn't Seem To Want To Start What Could Be The Problem Now?
Nov 14, 2007 at 1:34 PM
Try this:
If it fires and runs a few seconds with starting fluid (follow directions on can) then it is getting spark and there is a problem with the fuel system. If it doesn't even try to start, pull a plug, connect the plug wire to it, ground the plug against the engine block or other ground, and crank the engine to see if you are getting spark at the end of the plug.
Let me know what you find.
joe
Mar 22, 2009 at 12:40 AM
