Where is the EGR valve located?
1987 PLYMOUTH RELIANT
75,000 MILES • 4 CYL • FWD • AUTOMATIC
DELYLE
On the 1987 Reliant, where is the EGR valve located? I've got code 34 that states the EGR solonioid circuit is open. Does this pertaiin to the EGR valve itself or an electronic component somewhere?
Thanks,
David
Mar 22, 2008 at 7:10 PM
SERVICE WRITER
  • 9,123 POSTS
I expect that is is related to the electronic portion.
https://www.2carpros.com/forum/automotive_pictures/30961_egr_2.jpg
Solenoid is on the right front shock tower below the cover. I assume this is carbureted.
https://www.2carpros.com/forum/automotive_pictures/30961_egr1_1.jpg
Mar 22, 2008 at 8:44 PM
DELYLE
[quote:b191a7a7e7="delyle"]Engine Performance problem
1987 Plymouth Reliant 4 cyl Front Wheel Drive Automatic 75000 miles
Thanks,
David[/quote:b191a7a7e7]
Thanks for the reply but there is nothing on the right front shock tower - at least nothing that looks as complicated as what you diagramed. By right I assume you mean the passenger side.
I was able to locate the EGR valve and it's on the back side as the intake is located on the back side of the motor next to the firewall.
Any other place I should look for this electronic contraption?
Thanks again,
David
Mar 25, 2008 at 12:30 PM
SERVICE WRITER
  • 9,123 POSTS
I based this on carbureted, is this fuel injected?
You can access this info through this link:
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Mar 26, 2008 at 8:52 AM
DELYLE
[quote:284a595286="Service Writer"]I based this on carbureted, is this fuel injected?
https://www.2carpros.com/kpages/auto_repair_manuals.htm[/quote:284a595286]
Thanks. It has a carburator.
Mar 26, 2008 at 11:51 AM
SERVICE WRITER
  • 9,123 POSTS
Okay, the electrical portion, on top op the right front tower, but it is attached to the firewall as it looks to me.
And I would agree on the valve, as that is what it looks like in the picture.
What makes this tough, is I am working with information that is not always accurate, but you have the car. Probably been 10 years since I've had one in the shop. Component locations can be a bit vague.
Mar 26, 2008 at 3:09 PM
