Other Category problem
1986 Plymouth Reliant 4 cyl Front Wheel Drive Automatic 200k miles
when the car has warmed up, the temp indicator is in the normal range. every so often, the temp indicator goes 2/3 of the way up to max, stays a while then comes back to normal. what would cause this type of problem since it just started doing this? thank you for your kind attention to this matter. gameguy
Jan 3, 2008 at 10:29 AM
