Turn signal and other signal problems
PLYMOUTH
DTBRUNICK
I have a 1993 plymouth sundabce duster and the brake lights stopped working and the rear right turn signal doesnt work. The front right signal and the left side turn signals all work, except for the following:
When I turn the lights on the left side blinkers stop working, but the front right side still keep on blinking when turned on with headlights, help!
The headlights work fine both low and high beams
the left side turn signals work fine without head lights turned on.
the right front turn signal only works, it doesnt matter if headlights are turned on or not
the backup lights do not work
Interior lights work and license plate lights work
fog lights work
Help! :D
Oct 20, 2007 at 5:12 PM
DTBRUNICK
[quote:3a1f1bda6d="Rodimus-Prime"]intersting who put on the fog lights? You have a short either in bulbs between park and brake light bulbs, bad wiring due to a trailer hookup done badly, or the fog lights are hooked to wrong circuit.[/quote:3a1f1bda6d]
The fog lights were factory installed and have a push button switch on the dash to tun on or off. There is no trailer hitch installed, I thank you for your kind responce. I did find a rear tailight bulb receptor with a broken wire going into the bulb not the ground, I drilled this out and place the wire inside opening it up so as to make sure there was goog contact. I guess ill just have to get a continuity tester to trace out the lines then. Thanks
Oct 21, 2007 at 6:18 AM
