transmission probleme or something else
PLYMOUTH
YVAN
  • 4 POSTS
hello everybody
i have a 1994 plymouth 3.3 V6
and have several problems
my starter wont crank
i found out that i also have a cooling leak
and when i engage a gear it seems like if its on neutral only the parking gear work's
thank's for any help
yvan.
Jul 25, 2006 at 11:59 PM
Hi:
If you are getting no response from the trans, make sure the ATF is full. If it it is, has the check engine light come on? There could be a sensor problem, but honestly, if you get nothing, it sounds like a problem with the valve body or something internal. As far as the starter, have a helper turn the key to the start position (when the starter isn't working) and check for 12 volts to the smaller wire on the starter.
Let me know what you find.
Mar 22, 2009 at 1:52 PM
