To change or not to change!
PLYMOUTH
JOE1974
I have a 1998 Plymouth Neon Highline , 2L, 4 Cylinder with mileage around 90,000. I have the coolant (also called anti-freeze?) leaking problem. The mechanic gave me 300 bucks estimate to change the water pump, which has the leak. He also suggested that the car can have a new timing belt for an extra 100 bucks. The recommended timing belt replacement for this model is at 105,000 miles. What shoud I do? Is there any relative advantage in having a new timing belt? what if something else fails in a coupleof years? Owners of the same model, please help me get an idea.
Thanks. Joe
Nov 9, 2007 at 3:09 PM
MERLIN2021
  • 17,250 POSTS
105,000 I guess you live in Cal, or Mass? these are the only 2 states thar require the 105,000 timing belt, Yes if the water pump leaks, change them both, the advantage is if the belt breaks, the engine is destroyed!00.00 is cheap insurance!
Nov 9, 2007 at 3:13 PM
