Plymouth Repair Questions
PLYMOUTH
SAM157736
  • 5 POSTS
So here is how it goes. I have a 95 blue plymouth van. I was driving along when it started to loose power. It would still move slowly like 1 km/h but it would just sputter. I turned it off and let it sit for a min. than tried it again and it worked for about 30 min than it lost power and did the same. Can anyone help me!
P.S. I read that it could me the Pcm or something.
Jun 12, 2007 at 8:06 AM
SERVICE WRITER
  • 9,123 POSTS
What happens when it stalls out. Will it crank at all when you try it again. WE need to determine if this is a performance problem or an electrical problem.
Jun 12, 2007 at 8:18 AM
SAM157736
  • 5 POSTS
Yes it works fine for another 30 min.
Jun 13, 2007 at 12:10 PM
SERVICE WRITER
  • 9,123 POSTS
pcm is possible. I would hook up a fuel gauge and find the pressure. If it isn't is spec, then you may have a pump problem.
Jun 13, 2007 at 12:19 PM
SAM157736
  • 5 POSTS
Thanks I will try it!
Jun 13, 2007 at 12:53 PM
SAM157736
  • 5 POSTS
I tried that and it was fine. Any other ideas!
Jun 14, 2007 at 12:14 PM
SERVICE WRITER
  • 9,123 POSTS
Two things. First geting the codes read from the computer would be helpful. Second would try a intake valve cleaning procedure and other carbon removal techniques.
First access the throttle body and clean the throttle plate with intake cleaner and a soft brush or rag to remove the carbon fronm the plate and bore surfaces. While your part way there get a look at your air filter and replace it if it needs it. Next add the appropriate amount of seafoam to the fuel tank and also to the intake. It is writen on the bottle but post if you have any questions. Seaform is available at most parts stores.
Jun 14, 2007 at 3:21 PM
SAM157736
  • 5 POSTS
Hey thanks i will try!
Jun 18, 2007 at 7:02 AM
