Plymouth Laser 2ltr turbo..ignition coil problem??
PLYMOUTH
TROUBLED_LASER
hi, i recently took my car in for a diagnostics test because my ignition coil went from usin 4 cylinders down to 2(i only have one coil)
the report came up as an ignition coil failure so i replaced the coil, it worked fine for 30-40 minutes of driving, then it went back to two cylinders...i replaced the leads and coil for a second time and the same thing happened after 30-40mins.. i've spoke with a few people and they arn't sure whats wrong..maybe the ecm?? please can you help me as i dont want to waste any more money on this vehicle...thanks alot..anthony
May 18, 2006 at 9:29 AM
When this happens, does the check engine light come on?
Mar 17, 2009 at 8:29 AM
